Import ArcGIS Web Appbuilder applications into Local Portal?
1921
05-14-2018 11:58 AM
GarrettMcBride
Is there a way to load my existing web appbuilder applications into my own local portal?  I see the option within portal to create a new application using web appbuilder, but i wanted to import an existing application that was previously created with custom widgets.  The main goal is to use portal/Active directory to secure the web application.
DerekLaw
Esri Esteemed Contributor
Hi Garrett,
No, Portal for ArcGIS does not support importing any web apps into its internal content directory.
Workflow: you would host your web apps on your own 3rd party web server, then register the app as a new Portal item.
Add items—Portal for ArcGIS | ArcGIS Enterprise
Hope this helps,
GarrettMcBride
Thank you, i found that publishing to my federated ArcGIS Server solved my problem.  So simple, i was publishing to a non federated!  Thanks for the help.
