I'm looking for a widget similar to info summary that will allow a user to draw a polygon or select a boundary and receive a report of all features that intersect that area. The info summary only uses map view.
798
12-30-2018 01:15 PM
MZezima
Tags (1)
MZezima
Thank you! Found what I was looking for here:
https://doc.arcgis.com/en/web-appbuilder/create-apps/widget-screening.htm
It will search all layers within a map that intersect with user defined shape and It returns a full report you can design to look like a professional report and download or provide a web link to results.
RobertScheitlin__GISP
My identify widget is probably the closest match for what you are looking for and what is available.
https://community.esri.com/docs/DOC-3250-identify-widget-version-23-02172017
JeffreyROLAND
New Contributor III
I believe the Screening widget has this ability too.
MZezima
