HTTP Error 404. The requested resource is not found
10064
16
11-19-2015 06:08 AM
KCCGIS_Team
New Contributor III
I have downloaded the application code from web appbuilder developer version 1.2  and  hosted in my local IIS Server.
But when I try to run the application with this url “http://localhost/simple/ “ it start fine later it give the below shown error
Can anyone suggest me how can I fix this issue.
Thanks
KCCGIS_Team
New Contributor III
Hi Robort,
I have made the change to http in signininfo.json file but it is being overwritten when I created a new app in WAB Dev.
Guess I need to create a new app ID ?
RobertScheitlin__GISP
KCC GIS Team,
   I believe that you can rename the signininfo.json to something else and then when you startup WAB Dev it will ask for your portal url again and create a new file.
KCCGIS_Team
New Contributor III
Hi Robort,
I have done what you said but when I lunch WAB Dev it is openning in HTTPS
https://ABCD:3344/webappbuilder/?id=5 , hence the config file also have HTTPS by default
KCC GIS Team,
   Does your Organizations Portal configuration security settings have "Allow access to the organization through HTTPS only" checked?
KCCGIS_Team
New Contributor III
Yes!!!
KCCGIS_Team
New Contributor III
Thank you so much Robort for helping me in sorting this issue
KCC GIS Team,
Don't forget to mark this thread as answered. To do this you have to open the thread (you can not see the correct answer link from inside your inbox) and then you will see the green star with correct answer link. Just click that link on the thread that answered your question.
Robert
