How to auto-enable pop-ups
2214
04-18-2016 08:37 AM
TimHayes1
I am using Web AppBuilder Developer Edition 2.0.
How do I automatically enable pop-ups for certain layers? I want to set it up so my users do not have to take the extra step of "Enable Pop-Up" in the Layer List. I want the pop-ups automatically enabled so when a user opens up the map viewer they can start clicking on the layer they want and the pop-up will appear.
Is there a code snippet I need to modify?
RobertScheitlin__GISP
Tim,
  Have you cleared your browsers cache and restarted WAB? I have no additional steps to get popups to work for layers that have popups enabled in the Web Map.
Tim,
  If you have the layer in the Web Map configured for a popup then that will automatically translate over to WAB and you can just click on that feature in the map.
TimHayes1
I did that, then saved, then Launched. I still had to go enable popups in the Layer List.
Tim,
TimHayes1
Thanks, Robert. That did the trick.
