How to add mpk in webappbuilder?
835
11-09-2016 02:57 AM
MathanManohar
I have an Civilian.mpk with layers, Now I want to publish the Civilian.mpk through webAppBuilder with selected themes/widgets.
I had added the civilian.mpk in ESRI Online account. I tried to add in webapp Builder, But I cannot find the civilian.mpk in tabs []. But I can view the webmaps.
Query:
1. How to add the .mpk in web app builder?
2. How to set as basemap in webappbuiklder which is in ESRI Online account ?
RobertScheitlin__GISP
Mathan,
  1. You can not use a .mpk directly in WAB. You would use the .mpk in ArcMap and then publish your mxd to ArcGIS Server as a map service and then add that map service to a web map in your portal and then the web map can be used in WAB.
  2. You choose the basemap for your web map in AGOL when you are setting up your web map.
Make your first map—ArcGIS Online Help | ArcGIS
MathanManohar
Thanks a lot Robert,
This is what I am expecting.
Mathan
