How do you get newly added fields to show up in the edit widget?
3436
24
02-09-2018 01:51 PM
deleted-user-qzyyiYme1rz9
I recently added a few fields to a feature service and they show up correctly in pop-up in the map, however when I edit the settings for the edit widget web appbuilder the new attribute is not visible as an option for editable or viewable attributes. I have also tried completely deleting the edit widget, saving and re-adding it with no luck. The edit box is checked next to the new attributes in the pop-up configuration. I really need to make this new field editable via the edit widget in our app. Any ideas?
FrancescoGiovinazzo
I think I am going to save a lot of lives here, because I have discovered a workaround that fixes the problem.
By using Livia suggestion and checking ArcGIS Online Assistant (which I suggest to use, is very powerful) I doscovered that the real problem is not in the editor nor the app, it is in the MAP!
If you open the map json and scroll to your layer information, you will discover the fields definitions, something like:
"fieldName": "NOTE_RISOLUZIONE",
"label": "NOTE_RISOLUZIONE",
"isEditable": true,
"tooltip": "",
"visible": true,
"stringFieldOption": "textarea",
"isEditableOnLayer": true
This definition is perfectly correct, but if you scroll to your NEWLY ADDED FIELDS
"fieldName": "CATEGORIA",
"label": "CATEGORIA",
"isEditable": false,
"visible": true,
"stringFieldOption": "textbox"
See something missing?
This option is not getting added when you add new fields to a service, thus not working correctly in the Editor Widget
Add that option to true, save the json, open your WAB and shazam!, your newly added fields will be in the editor widget config window.
IMHO this is a BUG and should be addressed by ESRI
ScottEvans6
Awesome! Thanks!
FrancescoGiovinazzo
You are Welcome! Please up-vote the answer if it was helpful solving the problem
LiviaBetancourtMazur
Ah, that is helpful to know that the JSON of the map rather than the app should be fixed! Thanks!
BrandonBoisvert
It appears I can only view the json... do I need to do something to have editing permissions?
