How: Change the target Web Map in the JSON of a Web App?
1657
11-19-2020 02:38 PM
RVx_GaslineGiS
I needed to make changes to the JSON of an existing web map that is part of a web app. Before replacing it, I want to test the JSON changes on a new web map.
The new web map is a near duplicate the replacement--including its data sources, published services, and the layer ID. The main difference is in the itemIDs it uses to reference several feature layers.
The Web App uses a lot of configured widgets including different Searches, Group Layers, and the eSearch widget. I don't want to have to re-do any of those. Is there an easy location within the Web App's JSON I can change to point to the new web map instead?
LefterisKoumis
You can define the new web map id by changing it in the app config.json file. Look for the  itemId value found under the map object.
 "map": {
    "3D"false,
    "2D"true,
    "position": {
      "left"0,
      "top"40,
      "right"0,
      "bottom"0
    "itemId""<your map id>",
    "mapOptions": {
      "extent": {
        "xmin"-14304987.782245828,
        "ymin"3965994.21067048,
        "xmax"-12185541.861955022,
        "ymax"5115607.116079226,
        "spatialReference": {
          "wkid"102100
LefterisKoumis
 "map": {
    "3D"false,
    "2D"true,
    "position": {
      "left"0,
      "top"40,
      "right"0,
      "bottom"0
    "mapOptions": {
      "extent": {
          "wkid"102100
RVx_GaslineGiS
Thank you! I had been searching for where the map's itemID was but just couldn't locate it.
In retrospect, I suppose I could have used ctrl+f to and searched for the map's item id...
