How can I change the name of a widget?
6098
11
10-15-2015 08:41 AM
BarryBiediger
I copied the Search widget into another directory named SearchTest to add some custom functionality.  In this new widget, I changed the name in both manifest.json as well as in Widget.js, but when I go to add it in "Choose Widget" it still shows up as "Search" (now there are two "Search" widgets listed.)  All my changes are working when I add the new widget to the map, I just can't figure out how to make it show up as "SearchTest."
RobertScheitlin__GISP
Barry,
   In the repoitems file you will find i18nLabels object there you will likely find that your default label for your version of search is still named search. I think this might be becasue in the serch widget nls folder there is a _widgetLabel named "Search" try changing that and deleting the repoitems again.
BarryBiediger
Yes, that was it!  I was thinking the nls  widget label was only for the tooltip.  Thanks a lot Robert.
