Has anyone built a widget that requires user acknowledgement?
3665
03-19-2015 12:30 PM
TracyTroutman
Has anyone built a widget that requires user acknowledgement/disclaimer that they would be willing to share?
I have a requirement from our attorney to require user acknowledgement to the disclaimer on specify ArcGIS Online maps that we are making accessible to the public.  We found a template with a pop-up that the user can select a check box in but found out using the template that it caches the response and won't appear again if you re-launch the map.  I need it to pop up each and every time.
Any help, guidance or direction would be appreciated.
Tracy
RobertScheitlin__GISP
Tracy,
   Using the splash widget along with this code modification forces the splash widget to appear each site visit.
Re: splash widget problem
TracyTroutman
Thank you for the response.  We will see if we can get it to work.  I appreciate the support.
TimWitt2
Replace your splash widget folder with this one and it should work.
TracyTroutman
Thanks - We will give it a try.  I appreciate the help
