GPMultiValue:GPFeatureRecordSetLayer is not supported for now
499
09-22-2023 02:40 AM
JacksonKimani
New Contributor II
Hello community.
I need assistance with this error. I trying to create a tool for users to upload shapefile data to a feature service layer hosted in ArcGIS online, but I keep getting the error "GPMultiValue:GPFeatureRecordSetLayer is not supported for now"
I need assistance on this error to help me publish a shapefile on portal after uploading. temporary uploading and visualization is working but publishing is not. Thank you.
MichaelBranscomb
Esri Frequent Contributor
Can you provide more information about your workflow and share your code?
JacksonKimani
New Contributor II
Workflow:
I publish the 'Append Tool' as a web tool with ArcGIS Pro to ArcGIS Enterprise. The Source layer is a parameter and accepts shapefile, file gdb etc. Target layer is fixed. Its a feature service hosted on that enterprise portal.
I also checked the box for 'Upload' option in Capabilities and in the Content section I made the Input Dataset as 'User Defined'.
After publishing it, when I add this geoprocessing service to Web AppBuilder, it shows that error within the input option.
PS: I have attached 3 screenshots that show the flow for your review and assistance
MichaelBranscomb
To confirm, you're using Web AppBuilder and not the ArcGIS Maps SDK for Java?
JacksonKimani
New Contributor II
Yes, I am using Web AppBuilder.
