Geocoder: Default on Layer Search or Multiple Search?
3055
06-24-2015 11:42 AM
AdamAraza1
Is there a way to set the geocoder widget to default on the searchable layer upon open? Or is there already a downloadable widget somewhere that allows me to search layers and the geocoder at the same time?
TobiasFimpel1
Hi Adam,
here is one way to modify this in the widget's .js code:
Line 199 in [...]\arcgis-web-appbuilder-1.1\server\apps\[...]\widgets\Geocoder\Widget.js
//geocoding widget original configuration: geocoding service is default, feature layer search is secondary choice.
this.config.geocoder.geocoders = this.config.geocoder.geocoders.concat(querys);
//geocoding widget will only contain the feature layer search.
this.config.geocoder.geocoders = querys;
//geocoding widget will contain both geocoder + feature layer search and will default to feature layer search.
this.config.geocoder.geocoders = querys.concat(this.config.geocoder.geocoders);
TobiasFimpel1
Hi Adam,
ZeZhengLi
Hi Adam,
If you want to search features, you need to add a query type geocoder object to config.geocoder.geocoders.
The next release will use search widget replace Geocoder, so users could set searchable layer in setting page.
