Font family issue in Layer List Widget and jimu.css
8459
18
07-27-2016 11:14 PM
AnninaHirschi_Wyss1
Dear all,
I don't know if that is already a known issue, but I personally don't like the font-family used in the LayerList widget, after the update of WAB 2.1 (online and dev).
So (for dev version only) I searched a bit in the CSS's and found some font-family definitions like Avenir-Medium, instead of Avenir Medium.
Basically I replaced all the appearances of that "-" in the following files, which fixes it.
- \LayerList\css\style.css (Lines 4, 30, 459, 493)
- \jimu.js\css\jimu.css (Lines 3597, 3746, 3776) (affects other widgets, e.g. “Robert’s eSearch Widget”)
I also informed the Esri Support Team about it.
Regards,
Annina
PS: Just got a note from support that they already logged a bug: BUG-000097347: The font used for items in the Layer List widget doe..
BarnabyRockwell
Hi Robert!
I'm checking now in IE11 console......
Barnaby
Edit:
@font-face failed OpenType embedding permission check. Permission must be Installable.
jimu.js init...
What the.....  ??????????????????
Edit2:
From jimu.js:
@font-face {
  font-family: "Avenir Light";/*LT W01 35*/
  src: url("./fonts/3511a780-31ca-4ee1-9083-89b1b7185748.eot?#iefix");
  src: url("./fonts/3511a780-31ca-4ee1-9083-89b1b7185748.eot?#iefix") format("eot"), url("./fonts/c4352a95-7a41-48c1-83ce-d8ffd2a3b118.woff") format("woff"), url("./fonts/3e419b5b-c789-488d-84cf-a64009cc308e.ttf") format("truetype"), url("./fonts/ca038835-1be3-4dc5-ba25-be1df6121499.svg#ca038835-1be3-4dc5-ba25-be1df6121499") format("svg");
Offending file in bold.
RobertScheitlin__GISP
Make sure your web server has the .wof mime type set.
BarnabyRockwell
Ok, Robert.  I am out of my depth here, but I will look into it.
Many thanks,
Barnaby
BarnabyRockwell
Thanks, Robert!!!!
I was also looking at this:
Setting Mime Type for WOFF Files on Windows Servers
Adding .woff mime fixed the problem!
BarnabyRockwell
Note that WAB Dev 2.2 was just released.  I hope the font fix is in it, also.
AnninaHirschi_Wyss1
Yes! It's fixed also in Dev , BUT: They missed a few:
- line 3829 (appstate-popup) (not so very important)
- line 3978 (.popup-menu .menu-title .label) > visible in the select widget, and here Avenir-Roman is used, that is not even defined, as it seems. Replace by Avenir Medium or so
\widgets\Select\setting\css\style.css (Widget config page)
- line 9
- line 28
JamesCrandall
What exactly is the suggestion here?  I can locate these references but I'm not understanding what I'm supposed to do.
JamesCrandall
Is there a comprehensive list of things to do in order to fix this issue?
I'm not sure if I've captured everything suggested in this thread because I think I've implemented the suggestions but I'm still seeing an issue with the Layers List widget.
This is also happening in WAB Developer 2.4
