Elevation Profile Widget using Hi-Res DEM in Server
516
04-08-2021 02:32 AM
TunaUnsal
I am seeking the possibility of creating an "Elevation Profile Widget" which uses the high resolution elevation model I have in the server. The tool created by RobertScheitlin__GISP is great but I need to use the 1m elevation data of my own to have more accuracy.
A few years ago I tried to publish a geoprocessing service (created with  model builder) to use in the portal as I was able to do with some others but failed for elevation profile.
A few years past and hoping that a solution for this has been found. At least an idea could be given.
Tuna
CatherineMcIlwraith
Did you ever find a solution to this problem? I'm hoping to configure the Elevation Profile widget to reference a 1m elevation image service (rather than the default Esri image service) but struggling to find out if it is possible.
Many thanks.
TunaUnsal
Unfortunately I did not. Will certainly post if I find any.
