Draw Widget - How to save drawing
4294
12-13-2017 03:59 AM
MARTINWILSON1
Hi Guys
I have added the draw widget to my map.  The drawing functions work fine on the published app, but there is no way to save the drawing.  How do I do this?  I want to be able to send a link to someone of the map, and for them to mark on an area, save that area, and for me to open the map and see that area.
RobertScheitlin__GISP
Martin,
   You should look at the Enhanced Draw custom widget then:
GitHub - magis-nc/esri-webappbuilder-widget-eDraw: Ehanced draw widget for WebApp Builder for Arcgis...
Demo site:
ArcGIS Web Application
GeoguichetGeoguichet
Hello.
I dit not use eDraw, because I don't really like it/don't want this layers structure.
I'ts probably similar, but I did as follows in the standard Draw Widget, in order to save and load a drawing (to/from file):
var graphics = this._getAllGraphics();
var jsonString = "[";
array.forEach(graphics, lang.hitch(this, function(g){
   jsonString = jsonString + "{\"geotype\":\"" + g.geometry.geoType + "\",\"graphic\":" + jsonRef.toJson(g.toJson()) + "},";
jsonString = jsonString.substring(0, jsonString.length - 1) + "]";
var filename = "Drawing.json";
return CSVUtils._download(filename, jsonString);
jsonRef refers to 'dojox/json/ref' and CSVUtils to 'jimu/CSVUtils'
And to import a JSON string/file:
var objects = jsonRef.fromJson(evt.target.result);
for(var i = 0; i < objects.length; i++) {
   var parsedGraphic = new Graphic(objects.graphic);
   var geoType = objects.geotype;
   this._onDrawEnd(parsedGraphic, geoType, null);
evt.target.result comes for a Reader object (onload event)
Ali_AbbasWajid
did this work for you? I am also looking to export or share the drawing (viewer license). Is it possible or only for creator locense?
