Does the Web AppBuilder support two side by side maps?
5951
13
04-18-2016 11:44 PM
RobinKlaassen
We would like to use the Web AppBuilder (currently using v1.3, but we're in early stage so moving to 2.0 is also an option) to create an application that shows two different maps side by side, with some custom functionality to link places in both maps. It doesn't seem like this is natively supported however, so I was wondering if anyone has worked on something similar, and if the Web AppBuilder is the right tool for this job or if we have to move to another ArcGIS product.
Thanks in advance for your replies
ShayTsadik
I need to create an application that shows two different maps side by side.
Have you found a solution or developed a solution?
Thanks.
RobertScheitlin__GISP
There is no OTB way to do this and I have not seen any custom development for something like this.
GisGKAuckland
ShayTsadik
Thanks but I need it to work in WAB because I need to add some custom widgets to it.
