Custom logo on WAB Dev
1778
01-28-2019 11:47 AM
GajananBalasubramaniam1
What is the best practice to adding a custom logo to WAB? This isn't to replace the esri text at bottom right but rather to add custom logo on bottom left corner of the map.
I was able to do it with the following code in the index.html:
.map .esriMapContainer .esriMapLayers:before {
background-image: url(https://customlogo/image.png);
background-size: cover;
background-repeat: no-repeat;
position: absolute;
bottom: 2px;
left: 5px;
z-index: 1000;
height: 36px;
width: 148px;
content: ' ';
padding: 0;
This does exactly what I need, except for the part where it also adds the logo to the overview map, with the same size.
Any idea as to remove this from the overview map or a better method of adding the logo?
RobertScheitlin__GISP
Gajanan,
   This will keep it out of the overview map:
.map .esriMapContainer>#map_layers:before {
Gajanan,
Thank you so much Robert. That worked like a charm!
