Control the search radius of the identify pop-up widget
2980
07-06-2015 02:21 PM
VinceGuillet
New Contributor III
Is it possible to control the radius searched when the identify widget is invoked?  The out of the box distance is returning too many features due to the close proximity of features in my dataset, even when zoomed in tight.
RobertScheitlin__GISP
Vince,
   Sure in the in the Identify widgets configuration UI you can set the "Identify Tolerance", by default it is set to 5 pixels.
Vince,
haThach
New Contributor III
Robert,
This work with identify widget. Can I do the same thing with regular popup that originally setup in AGOL?
Ha,
   No the "regular popup that originally setup in AGOL" does not use the identify task.
