In Basemap Gallery widget, I am trying to configure two different basemaps: 1) World Imagery and 2) Organization's map which are having wkid: 3857 and wkid: 28355 respectively. While configuring these it's saying, "The basemap you are adding has a different spatial reference from the current map".
When I go through the Basemap Gallery widget of Web appBuilder docs,there it's said that 'Basemaps with Different spatial reference is unsupported'.
Are there any ways to change the spatial reference and can make it work?
Please suggest.
Thanks in advance.
Regards,
Naveen Kumar Kairamkonda.
Naveen,
No there is not. You need to make a copy of your data in WKID 102100/3857 if you want to use it with esri basemaps. The process is not as hard as you would think if you use Geodatabase replication and a nightly script to fire the synchronization (I have had this process running for years now).
