Change font size for group layer in LayerList widget
773
04-30-2018 03:03 AM
MarkCooper5
Occasional Contributor II
Hi
I would like to change the font size for the group layer name (service) in the layer list widget in order to make them stand out more. I have looked at the CSS file for the widget but cant work out how to do this. Is this possible at all?
Many thanks
Mark
Tags (1)
RobertScheitlin__GISP
Mark,
   Here is what you will need to change.
1. In the LayerList widgets style.css. Add this new css rule.
.jimu-widget-layerList .div-content.layer-is-group{
  font-size: 12px;
  font-weight:bolder;
2. In the LayerListView.js: lines 95 - 98 are additions and line 101 is a change.
    addLayerNode: function(layerInfo, level, toTableNode, position) {
      var layerTrNode, layerTdNode, ckSelectDiv, ckSelect, imageNoLegendDiv, handle,
        imageNoLegendNode, popupMenuNode, i, imageShowLegendDiv, divLabel;
      var rootLayerInfo = layerInfo.getRootLayerInfo();
      // if(!this._layerNodeHandles[rootLayerInfo.id]) {
      //   this._layerNodeHandles[rootLayerInfo.id] = [];
      // init _layerDomNodeStorage for rootLayerInfo.
      if(layerInfo.isRootLayer() || layerInfo.isTable) {
        this._layerDomNodeStorage[layerInfo.getObjectId()] = {
          layerTrNode: null,
          layerContentTrNode: null,
          layerNodeEventHandles: [],
          layerNodeReferredDijits: []
      var layerTrNodeClass = "layer-tr-node-" + layerInfo.id;
      layerTrNode = domConstruct.create('tr', {
        'class': 'jimu-widget-row layer-row ' +
          ( /*visible*/ false ? 'jimu-widget-row-selected ' : ' ') + layerTrNodeClass,
        'layerTrNodeId': layerInfo.id
      domConstruct.place(layerTrNode, toTableNode, position);
      layerTdNode = domConstruct.create('td', {
        'class': 'col col1'
      }, layerTrNode);
      for (i = 0; i < level; i++) {
        domConstruct.create('div', {
          'class': 'begin-blank-div jimu-float-leading',
          'innerHTML': ''
        }, layerTdNode);
      imageShowLegendDiv = domConstruct.create('div', {
        'class': 'showLegend-div jimu-float-leading',
        'imageShowLegendDivId': layerInfo.id
      }, layerTdNode);
      ckSelectDiv = domConstruct.create('div', {
        'class': 'div-select jimu-float-leading'
      }, layerTdNode);
      ckSelect = new CheckBox({
        checked: layerInfo.isVisible(), //layerInfo.visible
        'class': "visible-checkbox-" + layerInfo.id
      domConstruct.place(ckSelect.domNode, ckSelectDiv);
      imageNoLegendDiv = domConstruct.create('div', {
        'class': 'noLegend-div jimu-float-leading'
      }, layerTdNode);
      var imageName;
      if (layerInfo.isTable) {
        imageName = 'images/table.png';
      } else {
        imageName = 'images/noLegend.png';
      imageNoLegendNode = domConstruct.create('img', {
        'class': 'noLegend-image',
        'src': this.layerListWidget.folderUrl + imageName,
        'alt': 'l'
      }, imageNoLegendDiv);
      if (layerInfo.isTiled || layerInfo.isTable) {
        domStyle.set(imageShowLegendDiv, 'display', 'none');
        domStyle.set(ckSelectDiv, 'display', 'none');
        domStyle.set(imageNoLegendDiv, 'display', 'block');
      // set tdNode width
      domStyle.set(layerTdNode, 'width', level * 12 + 40 + 'px');
      var layerTitleTdNode = domConstruct.create('td', {
        'class': 'col col2'
      }, layerTrNode);
      var grayedTitleClass = '';
      try {
        if (!layerInfo.isInScale()) {
          grayedTitleClass = 'grayed-title';
      } catch (err) {
        console.warn(err.message);
      var layerTitleDivIdClass = 'layer-title-div-' + layerInfo.id;
      var layerGroupClass = '';
      if(layerInfo.getSubLayers().length > 0){
        layerGroupClass = 'layer-is-group ';
      divLabel = domConstruct.create('div', {
        'innerHTML': layerInfo.title,
        'class': layerGroupClass + layerTitleDivIdClass + ' div-content jimu-float-leading ' + grayedTitleClass
      }, layerTitleTdNode);
Mark,
  font-size: 12px;
  font-weight:bolder;
          layerTrNode: null,
        'class': 'col col1'
      }, layerTrNode);
          'innerHTML': ''
        }, layerTdNode);
      }, layerTdNode);
      }, layerTdNode);
      }, layerTdNode);
      var imageName;
      } else {
        'alt': 'l'
      // set tdNode width
        'class': 'col col2'
      }, layerTrNode);
      try {
      } catch (err) {
MarkCooper5
Absolutely perfect. Thank you Sir!
