Cannot read property 'set' of undefined this.FieldsCombo.set('store', FieldStore);
4089
7
02-09-2019 02:58 AM
NadirHussain
<div>
<label class="width70" for="FieldsCombo">Fields:</label>
<div data-dojo-attach-point="FieldsCombo" data-dojo-type="dijit/form/FilteringSelect" data-dojo-props="searchAttr:'name',intermediateChanges:true,placeHolder: 'Select Field'" class="dijit-form-FilteringSelect" style="width: 200px;height:30px;margin-Left: 51px;margin-top:5px;"></div>
</div>
this.SourceCombo.watch('displayedValue', function(property, oldValue, newValue) {
for(var k=0;k<layerInfoArray.length;k++)
if(layerInfoArray.title==newValue)
break;
var requestHandle = esriRequest({
"url": "https://localhost:6443/arcgis/rest/services/BaseMap/MapServer/"+k+"?f=pjson",
"content": {
"tags": "dog,us",
"tagmode": "all",
"format": "json"
"handeAs": "json",
"callbackParamName": "jsoncallback"
requestHandle.then(requestSucceeded, requestFailed);
function requestSucceeded(response, io){
var fields=(response["fields"]);
var FieldStore = new Memory({data: fields});
this.FieldsCombo.set('store', FieldStore);--------->this line produces errors
function requestFailed(error, io){
alert(dojoJson.toJson(error, true));
'cannot populate filteringselect
Resultent data from rest end point
  1. 1: {name: "REGIONCODE", type: "esriFieldTypeString", alias: "كود المنطقة", length: 2, domain: {…}}
  2. 2: {name: "GOVCODE", type: "esriFieldTypeString", alias: "كود المحافظة", length: 5, domain: {…}}
  3. 3: {name: "CENTERCODE", type: "esriFieldTypeString", alias: "كود المركز", length: 9, domain: null}
  4. 4: {name: "NAMEAR", type: "esriFieldTypeString", alias: "الاسم بالعربية", length: 50, domain: null}
  5. 5: {name: "NAMEEN", type: "esriFieldTypeString", alias: "الاسم بالإنجليزية", length: 50, domain: null}
RobertScheitlin__GISP
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
Nadir,
   This is a similar issue as your last post. You have a scope issue "this" does not represent the widget in your requestSucceeded function because you have not hitched the scope.
requestHandle.then(lang.hitch(this, requestSucceeded), requestFailed);
NadirHussain
Dear Robert,
 I update the code as per your instructions but same error on same line.i use fieldsCombo with and without this key word.But same error on same place.
Nadir,
  I will have to see your full widget code.
NadirHussain
var _map, _FeatureLayer, _graphicsUtils, _Draw, _Graphic,_StatisticDefinition, _SimpleMarkerSymbol, _Color,
_FindTask,_FindParameters,_SimpleLineSymbol,_geometryEngine, _Query, _QueryTask, _SimpleFillSymbol,
_SimpleRenderer,_Point,selectedRegionCode;
var URLs = {
"RegionServiceUrl":"https://localhost:6443/arcgis/rest/services/BaseMap/MapServer/2",
"GovServiceUrl":"https://localhost:6443/arcgis/rest/services/BaseMap/MapServer/1",
"CentersServiceUrl":"https://localhost:6443/arcgis/rest/services/BaseMap/MapServer/0",
"LocalitiesCentroidUrl": "https://localhost:6443/arcgis/rest/services/MOI/Tables/MapServer/"
var mapLayers = {RegionLayer:[],GovLayer:[],CentersLayer:[]},autoCompleteDataResult=[];
var selectedSymbol,slelctedPolygon,symbolRegion,symbolGov;
define(['dojo/_base/declare', 'jimu/BaseWidget','dojo/query',"dijit/form/Select", "esri/layers/FeatureLayer","esri/graphicsUtils",
"esri/toolbars/draw", "esri/graphic","esri/tasks/StatisticDefinition","esri/symbols/SimpleMarkerSymbol",
"esri/Color","esri/tasks/FindTask", "esri/tasks/FindParameters","esri/symbols/SimpleLineSymbol",
"esri/geometry/geometryEngine","esri/tasks/query",'jimu/LayerInfos/LayerInfos',"esri/tasks/QueryTask",
"esri/symbols/SimpleFillSymbol","esri/renderers/SimpleRenderer", "esri/geometry/Point",'dojo/store/Memory',
"dijit/_WidgetsInTemplateMixin",'dojo/_base/lang',"dojo/data/ObjectStore","esri/request", "dojo/_base/json",'dojo/on',"dojo/dom",
"dijit/form/FilteringSelect",
'jimu/loaderplugins/jquery-loader!./JS/jquery.min.js,./JS/jquery-ui.min.js,./JS/bootstrap.min.js,./JS/jsgrid.js,./JS/jsgrid.min.js'
function(declare,BaseWidget,query,Select,FeatureLayer,graphicsUtils,Draw,Graphic,StatisticDefinition,SimpleMarkerSymbol,
Color,FindTask,FindParameters, SimpleLineSymbol,geometryEngine,Query,LayerInfos ,QueryTask,SimpleFillSymbol,
SimpleRenderer,Point,Memory,_WidgetsInTemplateMixin,lang,ObjectStore,esriRequest,dojoJson,on,dom) {
//To create a widget, you need to derive from BaseWidget.
return declare([BaseWidget, _WidgetsInTemplateMixin], {
// Custom widget code goes here
baseClass: 'jimu-widget-SpatialSearchQuery',
postCreate: function() {
this.inherited(arguments);
console.log('postCreate');
startup: function() {
var panel = this.getPanel();
panel.position.width = 260;
panel.position.height = 300;
panel.setPosition(panel.position);
panel.panelManager.normalizePanel(panel);
_map = this.map;
_FeatureLayer = FeatureLayer;
_graphicsUtils = graphicsUtils;
_Draw = Draw;
_Graphic = Graphic;
_StatisticDefinition = StatisticDefinition;
_SimpleMarkerSymbol = SimpleMarkerSymbol;
_Color = Color;
_FindTask = FindTask;
_FindParameters = FindParameters;
_SimpleLineSymbol = SimpleLineSymbol;
_geometryEngine = geometryEngine;
_Query = Query;
_QueryTask = QueryTask;
_SimpleFillSymbol = SimpleFillSymbol;
_SimpleRenderer = SimpleRenderer;
_Point = Point;
var layerInfoArray=[];
var lyrArray=[];
if (this.map.itemId) {
LayerInfos.getInstance(this.map, this.map.itemInfo)
.then(lang.hitch(this, function(operLayerInfos) {
this.operLayerInfos = operLayerInfos;
this.operLayerInfos.traversal(lang.hitch(this, function(layerInfo) {
layerInfoArray.push(layerInfo);
for(var k=1;k<layerInfoArray.length;k++)
lyrArray.push({"ID":layerInfoArray.id,"Title":layerInfoArray.title});
var myStore = new Memory({data: lyrArray});
this.SourceCombo.set('store', myStore);
this.TargetCombo.set('store', myStore);
//this.SourceCombo.on('change', lang.hitch(this, function(){
// console.log("Hello");
// alert("ffff");
//_getAllFields("Hello");
break;
"content": {
"tags": "dog,us",
"tagmode": "all",
"format": "json"
"handeAs": "json",
//var os = new ObjectStore({ objectStore: FieldStore });
_getAllFields:function (strLayerName,lyrInfoArray){
alert("In side"+strLayerName);
if(layerInfoArray.title==strLayerName)
break;
onOpen: function(){
console.log('onOpen');
onClose: function(){
console.log('onClose');
// onMinimize: function(){
// console.log('onMinimize');
// onMaximize: function(){
// console.log('onMaximize');
// onSignIn: function(credential){
// /* jshint unused:false*/
// console.log('onSignIn');
// onSignOut: function(){
// console.log('onSignOut');
// onPositionChange: function(){
// console.log('onPositionChange');
// resize: function(){
// console.log('resize');
//methods to communication between widgets:
NadirHussain
<div>
<div >
<label class="width70" for="SourceCombo" style="margin-top:-20px">Source Layer:</label>
<div data-dojo-attach-point="SourceCombo" data-dojo-type="dijit/form/FilteringSelect" data-dojo-props="searchAttr:'Title',intermediateChanges:true,placeHolder: 'Select Source Layer'" class="dijit-form-FilteringSelect" style="width: 360px;height:30px;margin-Left: 10px;margin-top:-10px;"></div>
</div>
<div>
<label class="width70" for="TargetCombo">Target Layer:</label>
<div data-dojo-attach-point="TargetCombo" data-dojo-type="dijit/form/FilteringSelect" data-dojo-props="searchAttr:'Title',intermediateChanges:true,placeHolder: 'Select target Layer'" class="dijit-form-FilteringSelect" style="width: 360px;height:30px;margin-Left: 14px;margin-top:1px;"></div>
</div>
<div>
</div>
</div>
Nadir,
  OK, I see your issue now. Your requestSucceeded function is inside the this.SourceCombo.watch('displayedValue', function. So you need:
        this.SourceCombo.watch('displayedValue', lang.hitch(this, function(property, oldValue, newValue) {
          for (var k = 0; k < layerInfoArray.length; k++) {
            if (layerInfoArray[k].title == newValue)
              break;
            "url": "https://localhost:6443/arcgis/rest/services/BaseMap/MapServer/" + k + "?f=pjson",
            "content": {
              "tags": "dog,us",
              "tagmode": "all",
              "format": "json"
            "handeAs": "json",
          function requestSucceeded(response, io) {
            var fields = (response["fields"]);
              data: fields
          function requestFailed(error, io) {
