Can you apply a wildcard to the URL parameters
2579
04-03-2019 05:59 AM
AndrewEdmonds1
I can open a map to a single feature using <mapID>&query=<layerID>,<fieldname>,Demolished 1987 but can I zoom to the extent of all features with %Demolished% as the field value?
And if so, what is the appropriate ASCII character?
RobertScheitlin__GISP
Andrew,
  No wildcard queries are not supported. The URL query uses equals in the where statement.
query.where = field.name + '=' + queryArray[2];
Not LIKE. So it will not work.
Andrew,
AndrewEdmonds1
That is a grave disappointment.  Thanks for the quick reply.
Andrew,
   If you are using WAB Dev edition this is something you could change though.
