My first attempt at creating a widget for web app builder.
Trying to incorporate a pattern where the symbols are defined and referenced in the config.json file.
I am able to create the in-panel widget, add it to apps and run it using a test config. All is well, interacts with the map after clicking a button.
The problem I am having is referencing to a simple marker symbol defined in the config.json file which looks like this:
I can add a graphic to the map at the mouse-click point is I define the symbol in code like this:
symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND, 10, null, new Color("#ff6666") );
however if I try this:
symbol = new SimpleMarkerSymbol(this.config.symbols.smsymbol);
I get nothing on the map.
