can I add photos embedded in WAB from Collector related table?
1610
03-29-2016 09:15 AM
by Anonymous User
Not applicable
I have an SDE database that I've configured to work with esri Collector, created attachments.  Now I want to build a WAB site and have the photos appear in the features attribute pop-up window.  I know I can configure the pop-up, but what do I place in the ADD Item photo fields to pull the blob photos in SDE?
JakeSkinner
Esri Esteemed Contributor
Hi Mike,
The following document may provide the solution you're looking for:
Show Attachments in Web Map Popup
The pop-up configured in the web map will be used in the Web AppBuilder application.
JakeSkinner
Hi Mike,
