Busy indicator won't go away
6855
11
08-24-2015 11:20 PM
AndersHillström
I have downloaded 1.2 version of AppBuilder Developer Edition. When I create an application for the first time everything works perfect. The second time the Map loads but the “busy indicator” is still showing and won’t go away. Some functionality stops working. If I then clear the browser cache the application works fine again the first time and the second time I run the application the “busy indicator” starts showing again and won’t go away. Has anyone else seen this and know why this is happening?
In the developer tools console (F12) it shows 8 errors: “Error: multipleDefine” that is not there the first time when the cache is cleared and everything is ok.
I get one more error: “Error: declare dijit.form.DataList: base class is not a callable constructor.Error: declare dijit.form.DataList: base class is not a callable constructor.”
RobertScheitlin__GISP
Anders,
   I have not seen or heard of this issue before. Have you tried re-downloading the app and overwriting the previous folder that you had it in?
HerdisGudbrandsdottir
Do you load any other frameworks e.g. in a custom widget? take a look at the thread here: multipleDefine error in dojoLoader it could have something to do with the order of the loading of frameworks.
The DataList error - in what .js file and line number does it occur?
JunshanLiu
Anders,
Which browser do you use?
GeorgeKatsambas
I also had numerous issues with V 1.2, the busy/working icon would not go away, widget editing and functionality were not working. Had to do numerous refreshes to get a response. I was useing IE 10, switched to Chrome and so far no issues yet, mind you just switched to chrome yesterday.
ZeZhengLi
Anders,
     We are able to reproduce the loading problem on IE10. As a fact, this is a bit tricky. We are working on it.
Zezheng
AaronLowe
I'm still getting this exact problem with IE 10 on WAB 1.3.  Is this still being worked on?
Thanks.
It seems to be a problem with timing.  If I delete the javascript api files from my Temporary Internet Files folder, it loads correctly without errors.
wadsonmakari
Did anyone find a solution to this problem?
GeorgeKatsambas
I had the same issue so use Chrome now.
AaronLowe
I worked around the issue by hosting the JS API locally and then added a Header to turn of caching so it has to download the API on every load.  Not sure why it works, but it is probably a timing issue.  Events fire out of sequence or something like that...  It works consistently now.
