Background color for About Widget
3138
15
05-16-2019 12:29 PM
EmilyCaruccio
I have a logo that I can not change. Unfortunately, the logo is dark and does not go with the dark gray of the logo therefore I've been asked to change the background color to a light gray or white.
I've attempted to go to the common.css to change the color but I have failed.
Which rule will I have to edit to change the background-color of the widget? (Using Dart Theme)?
EmilyCaruccio
It is transferring now:
https://giswebtest.dhec.sc.gov/diabetes
RobertScheitlin__GISP
Emily,
   If look at this url: https://giswebtest.dhec.sc.gov/diabetes/themes/DartTheme/common.css the change you made is not there.
EmilyCaruccio
The edited version is there now.
Emily,
   Try adding the rule to this file then.
https://giswebtest.dhec.sc.gov/diabetes/jimu.js/css/jimu-theme.css
EmilyCaruccio
That did it!!! Thank you so much!!!!!
AndrewBernish__MDOT_
Robert,
I am trying to change the background color and size of the About Widget in ArcGIS Web App Builder. I am using the Foldable Theme. My map is here: https://bit.ly/MDOT_Map_Vaccine and a screenshot of my current existing About image is pasted below. I do not like the legend widget because of the spacing and size so I created my own legend as an image (and used the About widget to place it). I want to make the background of this panel black and decrease the size so it doesn't cover so much of the map.  Really - I just don't know where to add the code (if in ago-assistant, where or in the HTML snippet where?).
Thanks!
