This is my first time using web app builder. I got to the point where I registered my apps URL properly, but must have used the wrong App ID....... I can't seem to get back to where I re-enter the appropriate app ID and am instead taken to a page that is blank and just says invalid redirect_uri
Anyone experience the same issue? Help! What should I do???
Hi, I've seen folks struggle when following the documentation exactly and copy/pasting the examples. Note in the documentation is the format supplied http://[machine].[domain]:3344/webappbuilder do not include the brackets [] in the url so the registered app url will be along the lines of http://mymachine.esri.com:3344/webappbuilder NOT http://[mymachine].[esri.com]:3344/webappbuilder
Hi, I also had the same problem. Finally, I solved it. I think we need to add the redirect URL as following when we add a new app.
