Add Map Centre Co-ordinates to Screening Widget Report
334
03-27-2019 08:19 AM
AndrewMurphy3
I have recently discovered the Screening Widget and it is a very useful widget for summarising and reporting on features within a certain buffer of a location.
The only thing is, the report generates a map but does not display the centre co-ordinates of the map (At least not on WAB Dev Edition v2.7) (useful if someone later wants to refer back to the location again). Is there any way this can be done or added as a piece of functionality? It would also be useful if the co-ordinates were in the same projection as those of the data frame of the webmap.
KanikaRathore
Hi Andrew, I am also looking for a way to add map centre coordinates to the report. If there is any workaround you have come up with, do let me know.
