Environment: ArcGIS Online Web App Builder.
Problem: The ability to filter multiple groups of layers, each group with different expression on different attribute, with the result be the conjunction or union of all expressions (Like the normal filter).
Sumnmary
Group Filter Widget needs to allow filtering based on the union or conjunction of different expressions at the same time (on different fields) like the case in normal filter.
Here's what I'm trying to do.
1. Low Scale (State-scale) Layer with clusters Symbology.
2. Medium Scale (Town-scale) Layer with Heatmap symbology | |
3- High Scale (block-scale) Layer with point location symbology |
The result is good.
However, Group filter widget is limited to only one attribute at a time (say, the crash town name or the crash date) and cannot filter more than one attribute on different values at once. The widget also cannot be added multiple times (instances) to the map, only one instance.
I would love to see this function.
I would also love to see this function.
I too would love to see this function!
I also would love to see this function
