Enable Symbol Rotation in Geometry settings within Smart Editor
589
02-03-2022 08:58 AM
Status: Open
MollyBurton
New Contributor III
It would be really helpful to have the option to rotate symbols using a click method (instead of entering an angle) on a web map within a web app. For example, when designing gas pipelines, fittings are depicted directionally (in the direction of flow). Users designing need to rotate the fittings to the corresponding direction based on the scenario. If there was a simple rotate tool or rotate function within the Geometry settings of the Smart Editor, it would make design tasks more flexible.
@MichaelKohn_PGE @AndrewJBeaman
2 Comments
AlixVezina
Hi @MollyBurton , thank you for posting this idea.
This will not be implemented in the Smart Editor at this time, as we are moving our efforts towards new developments in the 4x API (the new Editor in the ArcGIS API for JavaScript that you will also find in the new Map Viewer, Experience Builder, and other 4x applications).
This is a good enhancement request and I would recommend also posting it in the ArcGIS Online Community and tagging the Editor and the JSAPI.
MollyBurton
Thanks for the quick reply @AlixVezina!
I took your advice and added the post here with the Editor/JSAPI tags: Enable Symbol Rotation in Geometry settings within... - Esri Community
