For the number Infographic, it would be great if we could calculate the ratio between two different fields!
For example, when calculating the ratio row by row, and then averaging the data by map extent (Image 1) it gives a different answer to averaging the two different fields and then calculating the ratio (Image 2). The correct answer should be Image 2, but it is impossible to calculate this on the fly as the extent is constantly changing. In Image 1, we were able to calculate the ratio's in the database, but are of no use if the answer is incorrect.
An option to calculate ratio's by selecting the two different fields in Infographics would be extremely useful in many situations.
Image 1:
Image 2:
