I have noticed "attribute expressions" in web maps do not transfer to web apps or operations dashboards.
Can either this be changed so the attribute expression fields do carry over and can be used by widgets and/or dashboard tools.
Or can someone point me to how I can change the code to use them inside the agol assistant?
I have these in the web map attribute expressions.
DaysOpen{expression/expr0}
DateDiff(date(),$feature.ITEM_DATE_CREATED , day)/86400000
DaystoClose{expression/expr0}
DateDiff($feature.ITEM_DATE_CLOSED,$feature.ITEM_DATE_CREATED , day)/86400000
I have used similar "Date_Time BETWEEN CURRENT_TIMESTAMP - 7 AND CURRENT_TIMESTAMP" in other web maps for filters and that does transfer between apps.
Thanks
