Presently the default DPI value of the print widget in the Web AppBuilder is static and set extremely low (96dpi which is fine for screen viewing but inappropriate for printing) and can only be modified by changing the code in the Developer Edition. Users complain that maps created are low-res and have to be instructed to increase the DPI every single time they print.
Having the default DPI as a configurable widget option would solve this problem.
I have the same issue here!
Please allow us to set a DPI default!
