Please add "Default Author" setting to the Attribute Table configuration. The print widget has this and the author is printed on the printed image/PDF.
When the user selects Export all to CSV, the default author data could be added to the end of the data in the CSV. This would be nice because if you share the data, the end recipient would have documentation of the source of the data.
