Jeffery, you will have to write your own add-in for this. Essentially you will have to do something like this: (I don't know about NAD27 because of no relevance to me but this is the same idea)
- Add mouse click eventhandler to map
- Handle event and do geometry task on coordinate to find output format
- display result
private Map _currentmap;
public CoordinateTool(Map currentmap)
// TODO: Complete member initialization
this._currentmap = currentmap ?? MapApplication.Current.Map;
if(_currentmap != null)
_currentmap.MouseClick += CurrentmapOnMouseClick;
CurrentCoordinates = new CurrentProjectionCoordinates() {X = "0", Y = "0"};
DdCoordinates = new DDCoordinates() {X_DD = "0", Y_DD = "0"};
DmsCoordinates = new DMSCoordinates() {X_DMS = "0", Y_DMS = "0"};
//initialise service endpoints
_geometryservice = new GeometryService(MapApplication.Current.Urls.GeometryServiceUrl);
_geometryservice.ProjectCompleted += GeometryserviceOnProjectCompleted;
_geometryservice.Failed += GeometryserviceOnFailed;
private void CurrentmapOnMouseClick(object sender, Map.MouseEventArgs mouseEventArgs)
MapPoint point = mouseEventArgs.MapPoint;
if (point != null)
CurrentCoordinates.X = string.Format("{0:N4}", point.X);
CurrentCoordinates.Y = string.Format("{0:N4}", point.Y);
// Coordinates in WGS84 format
Graphic pointgraphic = new Graphic() {Geometry = point};
if (_geometryservice != null && _currentmap != null)
IsReprojection = false;
if (!_geometryservice.IsBusy)
_geometryservice.ProjectAsync(new List<Graphic>() { pointgraphic }, new SpatialReference(WKID_WGS84));
private void GeometryserviceOnFailed(object sender, TaskFailedEventArgs taskFailedEventArgs)
MainApplication.Handle("Error", taskFailedEventArgs.Error);
private void GeometryserviceOnProjectCompleted(object sender, GraphicsEventArgs graphicsEventArgs)
Graphic resultgraphic = graphicsEventArgs.Results.FirstOrDefault();
if (resultgraphic != null)
if (!IsReprojection)
MapPoint point = resultgraphic.Geometry as MapPoint;
if (point != null)
DdCoordinates.X_DD = string.Format("{0:N4}", point.X);
DdCoordinates.Y_DD = string.Format("{0:N4}", point.Y);
DmsCoordinates.X_DMS = string.Format("{0:N4}", DMSCoordinates.FromDecimalDegrees(point.X));
DmsCoordinates.Y_DMS = string.Format("{0:N4}", DMSCoordinates.FromDecimalDegrees(point.Y));
else
and the classes is something like so:
public class CurrentProjectionCoordinates : NotificationBase
protected string x;
protected string y;
private double surrogate = 0;
public string X
get { return (x); }
set
x = value; OnNotifyPropertyChanged("X");
public string Y
get { return (y); }
set
y = value; OnNotifyPropertyChanged("Y");
public class DDCoordinates : NotificationBase
private string x;
private string y;
public string X_DD
get { return (x); }
set { x = value; OnNotifyPropertyChanged("X_DD"); }
public string Y_DD
get { return (y); }
set { y = value; OnNotifyPropertyChanged("Y_DD"); }
