Joined tables not showing up in Viewer
2005
01-31-2012 05:30 AM
by Anonymous User
Not applicable
Original User: ryanstovern
When I was testing the beta we had a joined tax data table to our parcels table and the attributes were able to be viewed in the viewer, and now those joined tables are not viewable?
by Anonymous User
Not applicable
Original User: katydalton
Hi Ryan,
I know you posted this almost a month ago, but I wanted to check in and see if you sorted out the issue?
Is this the scenario you have:
  1. Create a map document with a layer that has a join to another layer or table
  2. Publish map document
  3. Add the map service as a layer in Viewer.
  4. Configures popups for the sub-layer with the join.  The fields from the join should be treated the same as any other field.
Or do you have a different scenario happening?
Katy
