Deployment errors
699
05-08-2012 05:00 AM
amzantel-masri
hi
I have a problem deploying my webpage.
In fact, i am using ArcGIS viewer for silverlight. When i am trying to deploy my data, i see that a folder having the same name of my deployment is created in Apps folder.
If i double click on index.htm to open it, i see a blank page and no data are displayed. But if i open ArcGIS viewer-Builder and i try to edit it, it opens normally.
Any suggestions?
Regards,
Amjad
KatherineDalton
Hi Amjad,
You might find our topic on Deploying" rel="nofollow" target="_blank">http://help.arcgis.com/en/webapps/silverlightviewer/help/i... applications helpful. Note that the recommended way to access a published Viewer application is through your browser by inputting the full address (for example: http://<machinename>/Apps/ViewerApplication.)
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
amzantel-masri
Hi Katy
Thank you very much for your reply.. I want to tell you that when i try to deploy the application with the way that you suggest me (according to the arcgis help) i get an empty page (first attachment) while the browser ask me to install the silverlight. But the silverlight is already installed. Furthermore, i get a reply from flidder regarding with the Viewer.xap (2nd attachment). The viewer.xap is a file inside the app/folder.
I want to ask where this errors are attributed to? and if there is a problem inside the silverlight application which obstruct the deployment of the web page.
Regards
Amzant el Masri
KatherineDalton
It might have to do with not having the correct MIME types set. Can you take a look through our System" rel="nofollow" target="_blank">http://help.arcgis.com/en/webapps/silverlightviewer/help/inde... Requirements document and make sure you have those set?
Also, the article Configuring" rel="nofollow" target="_blank">http://learn.iis.net/page.aspx/262/configuring-iis-for-s... IIS for Silverlight Applications might be helpful as it is specifically about setting MIME types.
Let us know if that works.
Katy
amzantel-masri
Hi Katy
I try what you suggest me and it is working now.. I add some mime types according to the Configuring IIS for Silverlight Applications.. and done.
Regards
Amjad
