Constrained Extent Behavior in ArcGIS silvelight viewer
3148
05-09-2012 10:17 PM
GhulamMustafa
Hi every1
I am a new user of arcgis viewer for silverlight. I am trying to find out the solution that constrained Extent behavior setting in viewer.Kindly help me to fix it.Thanks
KatherineDalton
Hi Ghulam,
I've placed our Constrain Extent sample on ArcGIS.com. You can access it from the ArcGIS Viewer for Silverlight Code" rel="nofollow" target="_blank">http://help.arcgis.com/en/webapps/silverlightviewer/gallery.htm... Gallery.
This is a complete Visual Studio solution, so you will need to open the solution in Visual Studio, build it, and then add the resulting .xap file to the Application Builder as an add-in.
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
GhulamMustafa
Hi Katty
Thx alot for quick reply.You did a wonderful job. If you could please extend this program that will ask user to enter XMin,Xmax,YMin and Y Max values. Thanks again.
GM
