TOC Widget issue: Cant see legend icons on sub layers
3426
14
04-30-2012 08:40 AM
AYounas
I am having an issue here i.e. I cannot see the symbols on 5th level sublayers. Please see the attached image where it says water after layer 3, there should be a symbol as well, which is not there. Any help please?
Regards,
Adi
P.S: Sorry for posting it as seperate thread to get quick response.
[ATTACH=CONFIG]13947[/ATTACH]
RobertScheitlin__GISP
Adi,
    I did not figure out why your layer did not work the way you had it... I even tried to reproduce exactly you layer and the rendering and I could NOT get it to NOT display the legend.
AYounas
I am surprised as well that is why I asked you, if you can kindly explain the reason why it happened.....and strangely it worked fine as per your suggestion. I got spaces in layer name like "A B 1-1000",  although a silly question but do u think it matters? as now I am having trouble in identify field :)...... Strange World!
Regards,
Adi
Adi,
Adi,
I don't know why it happened. That is what I am trying to say.
AYounas
can we have all of our layers expanded by default, please?
AYounas
Found the answer here: http://forums.arcgis.com/threads/52960-TOC-Widget-how-to-default-open-all-layers-so-that-legend-show...
