* MAJOR CHANGE when a layer of a map service or the whole mapservice is excluded using the excludelayers it
is excluded from the TOC and the map. This has changed from where it use to be visible in the map even
though it was excluded from the TOC. *Clarification* If you want to exclude a whole map service from the
toc and the map then you just remove it from the viewers main config. Currently if you exclude a map service
and do not specify any sublayers then the mapservice will remain in the map.
- Access of possibly undefined property id through a reference with static type com.esri.ags.layers.supportClasses:layerInfo - Access of undefined property JSON - Can not resolve a multiname reference unambiguously. JSON
