The window ???zoom in???and ???zoom out??? are missed in the ???map extent??? mode,
1068
12-27-2012 10:04 PM
JamalNUMAN
Legendary Contributor
Please, have a look in the screenshot below.
[ATTACH=CONFIG]20236[/ATTACH]
Here the ???zoom in??? and ???zoom out??? are provided which enables window zooming at the target area. While these two tools are missed in the ???map extent??? mode!
[ATTACH=CONFIG]20237[/ATTACH]
What might be the reason?
Thank you
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: Law
Hi Jamal,
The window ???zoom in??? and ???zoom out??? are missed in the ???map extent??? mode ...
This is correct and by design. In the first screen capture you provided, it shows the Preview tab of the ArcGIS Viewer for Flex application builder, which shows the navigation widget.
In the second screen capture you provided, it shows the Maps tab - which is not meant to display the navigation widget. You can still define a spatial extent bounding box on the tab by simply holding down the Shift key as you left mouse click to zoom in/out.
Hope this helps,
by Anonymous User
Not applicable
Original User: Law
Hi Jamal,
Hope this helps,
JamalNUMAN
Hi Jamal,
Hope this helps,
Thank you for the help Derek. This is very useful.
[ATTACH=CONFIG]20248[/ATTACH]
Best
Jamal
Jamal Numan
