The basemap of the Flex is repeating itself!
998
12-27-2012 08:30 PM
JamalNUMAN
Legendary Contributor
I???m wondering why the ???world??? is repeated many times in the basemaps of flex and thus our ???operational layers??? are repeated as well!
[ATTACH=CONFIG]20229[/ATTACH]
In my understanding, the basemap should appear just one time like what we have in Silverlight (if I'm correct)!
[ATTACH=CONFIG]20230[/ATTACH]
What might be the issue with Flex regarding repeating the basemap?
Thank you
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: Law
Hi Jamal,
The basemap of the Flex is repeating itself! I???m wondering why the ???world??? is repeated many times in the basemaps of flex and thus our ???operational layers??? are repeated as well!
This is not an error, but expected behavior. At the ArcGIS Viewer for Flex 2.3 release, we added support for:
Wraparound???Continuous pan across date line when working in the WGS84 geographic coordinate system or Web Mercator projected coordinate system. Set the new wraparound180 property on the <map> tag in the main configuration file to activate.
FYI, What was new in 2.3 and 2.3.1 Viewers release notes
Hope this helps,
by Anonymous User
Not applicable
Original User: Law
Hi Jamal,
Hope this helps,
JamalNUMAN
Hi Jamal,
Wraparound�??Continuous pan across date line when working in the WGS84 geographic coordinate system or Web Mercator projected coordinate system. Set the new wraparound180 property on the <map> tag in the main configuration file to activate.
Hope this helps,
Thank you for the answer Derek.
Where can I find the �??configuration file�?�?
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: GISDev01
That would be the "config.xml" located in the base folder of the Flex Viewer Code.
I think you need to read the documentation more.
