Search and Enhanced Search Widget Not Zooming
3927
11
06-01-2012 06:15 AM
ToddLaQuay
Both the Search Widget and Enhanced Search Widget will not zoom to the results of my dynamic map services.  I am using the compiled versions.  If I leave the Louisville sample data active in the configuration file it will zoom to those results when searched, but still not zoom to my services results.  Individual service capabilities include Mapping (Map Data Query checked on), Feature Access (Query Editing checked on) and KML and all combinations of turning those on and off.  zoomscale set to 5000 (tried dif numbers here too).  I'm stumped.  Never messed with the .swf file.  Even tried reloading a fress copy of the widget from the install files. Also tried in multiple flexviewer iterations.
MLowry
Are your ObjectID or geometry (shape) fields hidden? Post a screenshot of your REST pages for the services that it won't zoom to.
MLowry
ToddLaQuay
Both my ObjectID and Shape fields were hidden.  Turned them on and republished etc and now they zoom.  Thank you for the quick response!  Sure wish i would have found it noted somewhere that those were required to be visible.
DaveKirkley
My problem is the zoomscale does not seem to work
<zoomscale>5000</zoomscale>
   <forcescale>true</forcescale>
Using a Query Widget
But the Zoon always takes you in tight to the polygon
RobertScheitlin__GISP
Dave,
   The zoomScale will only take you to the closest LOD (Level of Display) if you are use cached basemaps.
Don't forget to click the top arrow (promote).
Follow the steps as shown in the below graphic:
Shingo-Ikeda
Hello Robert.
Thanks for the great widget. I have installed your latest 3.0 eSearch widget, but I noticed that segment layers get clipped to result extent (or display extent) when any type of search is applied and zoomed. It only seem to happen to only segment layers and not to point nor polygon layers. When I have multiple segment layers in the operational layers, they all get clipped and it won't get redrawn. Actually data does not get clipped, it just become invisible - therefore I can still query.
Have you seen this effect before?
Shingo
Shingo Ikeda
Geospatial Data Scientist/Developer - Geographical Information Platform
Global Power Generation - Digital Satellite USA and Canada
Shingo,
   I have not seen that before. I am using polylines in my live sample site and do not see that behavior either.
Shingo-Ikeda
Hi Robert,
Thanks for your reply. For some reasons, it was clipping the feature geometries by the intersected resulting geometry and not refreshed. I had to go through layers and refresh layers as shown below:
MapUtil.forEachMapLayer(map, function(layer:Layer):void
    layer.refresh();
I added above refresh function to clear() as well as new widgetclosehandler (dispatched when widget gets removed) in a mean time to fix the issue I was experiencing.
Shingo
Shingo Ikeda
DaveKirkley
Robert,
Using a Dynamic Basemap.
Zoom works on your enhanced search (great work by the way!)
But the Query I've set up... no luck
Dave,
   If you still need help with the query than post what you are trying to use.
