Rotate Map and Labels, then Print to PDF
2124
05-22-2014 12:18 AM
NatashaManzuiga
Hi, is it possible to rotate Map and Labels, too and Print to PDF?
I need this.
Naty
BjornSvensson
Natasha, there's a rotation property you can set for the map:
<map rotation="270" ...
Not sure if it that is that is the sort of "rotation" you are looking for. Or if it does everything you want, but maybe worth testing out.
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Map_content/01m30000005p000000/
