Print widget with services directory off?
1619
10-07-2013 11:59 AM
BillLotz
Is there a way to use the print widget with the services directory turned off?
AnthonyGiles
Honored Contributor
Bill,
From the help:
Disabling the Services Directory is recommended as a best practice for ArcGIS Server systems that are public. You may choose to enable the Service Directory on production systems, only if there is a need to make the HTML pages and forms available to the end users. Once disabled, users are not able to view and use the services using Services Directory HTML pages i.e requests that are made for HTML output format (f=html or when parameter f is not specified). They'll receive an error message if they attempt to access the Services Directory once it has been disabled by the admin. All client applications (Web APIs, Desktop, Mobile, etc.) that programmatically access the Services using JSON or other output formats will continue to function as expected.
So it should work, what may cause a problem is accessing the created file such as a PDF or jpg
Regards
Anthony
AnthonyGiles
Honored Contributor
Bill,
If you remove the URL for the printing service from the config directory it will revert to quick printing like previous versions:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Print_widget_tags/01m30000001n0...
Regards
Anthony
BillLotz
Hello Anthony, Thanks for the reply. I guess that I should rephrase my question; Is there any way to get the advanced printing to work if you have the services directory turned off? Thanks, Bill
AnthonyGiles
Honored Contributor
Bill,
From the help:
Regards
Anthony
BillLotz
Thanks for the answers. I see that it is fixed in 10.2        http://forums.arcgis.com/threads/89414-Print-task-does-not-work-if-servicesDirectory-is-disabled?p=3...
