popups 2.3.1 and thematic query - Urgent request
1404
05-09-2011 12:08 PM
RashidMalik1
First of all, let me say that I love all the enhancements in the newest flex viewer, 2.3.1.  One of my favorites are the enhanced popups.  Here is my issue though.  I am currently using 2.2 flex viewer and have several applications that are running on ArcGIS Server 9.3.1.  I have used the thematic query widget for many of these applications.  However, after clicking on a polygon using the thematic query widget, I would like to use the new poppus instead.  I currently list a few fields and generate a bar chart in the popup.  However, I just want to use the "pick a theme" widget only select a thematic map and a related legend.  I cannot use the dynamic legend feature currently as we have not upgrade to ArcGIS 10 yet.  Being able to do what I just described, would be ideal.  However, here is what will also work:
One of the field in my shapefile has a URL (i.e. www.google.com).  Using the old ThematicQueryWidget, I am able to list that field be it is not clickable as a URL.  Can you please tell me how can I make this field clickable.  I know it would be much simpler with the new popus but I would appreciate someone can tell me how to do this.  But, my first preference is to do what I stated in the first paragraph.  Thanks you so much.....
MehulChoksey
will submit after more testing tomorrow..
RashidMalik1
Super Mehul.  You are as helpful as ever.  Much appreciated.  Thanks...
MehulChoksey
Replace infoColumnChartItemRenderer with code below:
<?xml version="1.0" encoding="utf-8"?>
     // Copyright (c) 2010 ESRI
     // All rights reserved under the copyright laws of the United States.
     // You may freely redistribute and use this software, with or
     // without modification, provided you include the original copyright
     // and use restrictions.  See use restrictions in the file:
     // <install location>/License.txt
<s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                xmlns:s="library://ns.adobe.com/flex/spark"
                xmlns:mx="library://ns.adobe.com/flex/mx"
                autoDrawBackground="false"
                dataChange="itemRenderer_dataChangeHandler(event)">
    <fx:Script>
        <![CDATA[
            import mx.events.FlexEvent;
            [Bindable]
            private var fieldName:String;
            [Bindable]
            private var fieldValue:String;
            private function itemRenderer_dataChangeHandler(event:FlexEvent):void
                if (data)
                    if (data.alias)
                        fieldName = data.alias;
                    else
                        fieldName = data.field;
                    if (data.value != null && data.value is String && data.value.substr(0,7) == "http://")
                        fieldValue = "<a href='" + data.value + "'>" + data.value + "</a>";
                    }else
                        fieldValue = data.value;
    </fx:Script>
    <s:layout>
        <s:HorizontalLayout verticalAlign="middle"/>
    </s:layout>
    <s:Label id="field"
             width="100%"
             text="{fieldName} : "/>
    <mx:Text id="value"
             htmlText="{fieldValue}"/>
</s:ItemRenderer>
RashidMalik1
Thanks a billion Mehul.  Will test it shortly.  Thanks..
RashidMalik1
Worked like a charm.  Thank you so much.  Now I can achieve what I need to achieve...
BTW, in the future, if I wanted to use the 2.3.1 features like new popups and still use the "pick a theme" widget just to switch the theme and legend and clicking on a polygon uses the new poppus not the InfoColumnChartWidget or the InfoColumnChartItemRenderer.  This would be a fantastic if it can be done.  Thanks
