my date field is showing one day earlier than the attribute table in my popup. How do i fix this?
2844
8
09-30-2014 08:01 AM
BradGeorgic
New Contributor III
My flex viewer is showing the date field as one day earlier.  How do I fix it?
Tags (1)
RobertScheitlin__GISP
Brad,
  Manually edit your PopUp_47.xml file to look like this (I have tested and I get dates one day earlier than your app is showing):
<?xml version="1.0" ?>
<configuration>
    <title>Volunteer Opportunities</title>
    <fields>
        <field name="Date" alias="Date" visible="true">
            <format useutc="true" dateformat="MMMM D, YYYY"/>
        </field>
        <field name="PublicViewable" alias="PublicViewable"/>
        <field name="Department" alias="Department" visible="true"/>
        <field name="Contact" alias="Contact" visible="true"/>
        <field name="Description" alias="Description" visible="true"/>
        <field name="X" alias="X">
            <format precision="5" />
        </field>
        <field name="Y" alias="Y">
        </field>
    </fields>
    <showattachments>true</showattachments>
    <showrelatedrecords>false</showrelatedrecords>
</configuration>
To find this file look in your c:\inetpub\wwwroot\flexviewers\map\popups\PopUp_47.xml (the map part of the path is the only part I am not sure about, map would be the name you gave the application when you created it in AppBuilder).
Brad,
   So is it the popup or the attribute table that is wrong? Are you using the useutc attribute?
Popups useutc: ArcGIS Viewer for Flex - Pop-up configuration files
Attribute Table Widget useutc: ArcGIS Viewer for Flex - Attribute Table widgettags
BradGeorgic
New Contributor III
the popup is showing the wrong date.  The attribute table is correct.  I tried it both ways UTC and non-utc
Brad,
  please provide your pop up config.
BradGeorgic
New Contributor III
I am using the Flex- Application Builder.  How doe I get the popup info?
Map of Our Work
Brad,
   Which layer is showing the wrong date? Which service and sublayer ID number?
BradGeorgic
New Contributor III
Layer: WPC Volunteer Opportunities (ID: 0)
it is the date field in that service.  Thanks for the help
Brad,
<configuration>
    <fields>
        </field>
        </field>
        </field>
    </fields>
</configuration>
BradGeorgic
New Contributor III
Thanks.  I'm not sure why initially the use UTC didn't work in App Builder.  THANK YOU for the debug!
