Login Screen for the Flexviewer
34678
121
03-15-2011 10:52 AM
andrewj_ca
Occasional Contributor II
Just posted some code for a Flexviewer login screen.  I hope somebody can get some use from this.
http://www.arcgis.com/home/item.html?id=baebcaf317994d63902bc9735c0657e0
RobertScheitlin__GISP
Saurabh,
   I have updated by link in post 108 so that it links to the correct location in GeoNet.
SaurabhGupta4
Robert
Thanks a lot for the reply
Regards
Saurabh
tommykurniawan1
Hi Forums,
One time i need to create simple login mechanism for flex viewer 3.6, i create it like this
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
               xmlns:s="library://ns.adobe.com/flex/spark"
               xmlns:viewer="com.esri.viewer.*"
               xmlns:managers="com.esri.viewer.managers.*"
               pageTitle="ArcGIS Viewer for Flex">
    <fx:Style source="defaults.css"/>
    <fx:Metadata>
        [ResourceBundle("ViewerStrings")]
    </fx:Metadata>
    <fx:Script>
        <![CDATA[
            import mx.controls.Alert;
            import mx.managers.PopUpManager;
            protected function button1_clickHandler(event:MouseEvent):void
                if(text1.text == "P4ssw0rd")
                    Alert.show("Login success!");
                    viewerContainer.visible= true;
                else
                    Alert.show("Login failed!");
    </fx:Script>
    <fx:Declarations>
        <!-- Place non-visual elements (e.g., services, value objects) here -->
    </fx:Declarations>
    <s:Form id="form1" x="3" y="1" width="226" height="64">
        <s:TextInput id="text1" width="200" height="20" displayAsPassword="true" enabled="true"
                     prompt="Password"/>
        <s:Button left="60" width="100" height="20" label="Enter" click="button1_clickHandler(event)"/>
    </s:Form>
    <viewer:ViewerContainer id="viewerContainer" visible="false"  x="0" y="0">
        <viewer:configManager>
            <managers:ConfigManager id="configManager"/>
        </viewer:configManager>
        <viewer:dataManager>
            <managers:DataManager id="dataManager"/>
        </viewer:dataManager>
        <viewer:mapManager>
            <managers:MapManager id="mapManager"/>
        </viewer:mapManager>
        <viewer:uiManager>
            <managers:UIManager id="uiManager"/>
        </viewer:uiManager>
        <viewer:widgetManager>
            <managers:WidgetManager id="widgetManager"/>
        </viewer:widgetManager>
    </viewer:ViewerContainer>
</s:Application>
type 'P4ssw0rd' for password, and press enter
works fine for me,
Regards - Tommy
saurabhgupta2
Hello everyone
I have applied the above code to get a login screen up and running
Thanks for this great work. But still i am searching how to load different config file according to role of the user
Thanks and regards
Saurabh
Saurabh,
   The ability to have a certain config.xml based on the viewer that has logged in is part of the ArcGISSecurity web service found in this link:
https://community.esri.com/message/182812#182812
I am not sure which link you used to get your webservice for user validation but the one above uses a list of users names and passwords and the specific config to return once the user has successfully logged in.
saurabhgupta2
Robert
I have used the different one . I will try with the one you have provided ( devsummit 2012).
Just wanted to know ..
Can We some how pass the Username to my Main app to show which user have logged in ..something like" Welcome Username" . I have seen that some one has posted the same query but i guess it was not answered .
Regards
Saurabh
saurabhgupta2
Hello Robert
I have applied the code on IIS 8.5 ( gisbeta - /devsummit2012/ ). I got some error of duplicate records ( on line 14,16,17,18,19 of web.config) which i commented ( as i did in previous code  ) . After that i got directory browsing error which i resolved again. But now im getting this error. I have changed the line of username and password which u have mentioned earlier .
thanks and regards
Saurabh
Saurabh,
  Here is a VS2013 version that uses .NET 4.5.1 (since you are one windows 8). You will need to change the wsdl url in the index.html from
ws.wsdl ="http://yourserver/ArcGIS_Security/Service.wsdl";
to
ws.wsdl ="http://yourserver/ArcGIS_Security/ValidateUser.svc?wsdl";
As far as your question about returning the logged in user name. That is done in the Flex Viewer Files\src\index.html included in the zip file I linked in the previous post.
saurabhgupta2
Robert
I will try to integrate this one and will post the result accordingly
Thanks and Regards
Saurabh
saurabhgupta2
Robert
The service works fine but its not uploading different config file!! Am i missing something ?
I can see that service is returning the config file name from the xml but cant see any piece of code that uses the output config file except this one:
if(configFile != ""){
  var outArray:Array = configFile.split(",");
  usrConfigfile = outArray[0];
I am not able to get how to use this to load the specific config file
regards
Saurabh
