is there any chance to retrieving metadata of serviced layers
1824
10-20-2014 06:58 AM
AriefArianto2
I need to build widget that can retrieve the metadata of the layers that already serviced on the server, or perhaps modified the legend widget so the widget can display the metadata and the legend in the same time
RobertScheitlin__GISP
Arief,
   Are you talking about real metadata (like the metadata editor in ArcMap) or just info like description and copyright and basic stuff that you get from ArcGIS Server in the rest service directory? If you are wanting the description and copyright then you can use the eLayerList Widget http://www.arcgis.com/home/item.html?id=58d9bb5693c94918a3934781d7234d18‌ It has a description option in the dropdown menu for layers in the toc that returns this type of info.
Arief,
AriefArianto2
Thanks for the quick response Robert,
lol, not the real metadata, just wanting the description and all basic information. Thanks Robert. you solve my problems. much appreciated.
Arief,
     Glad to help. Now it is your turn to help the community by marking this question as answered. All you have to do is click the "Correct Answer" link (the one with the little green star) on the post that provided the answer for you. If the answer was not provided by one of the responders then you can mark any of the replies that you received as helpful by clicking on the "Actions" menu and choosing "Mark as Helpful"
