Is it possible to edit the ABOUT tab content in Flex Viewer?
554
03-18-2014 04:33 AM
RichardGeoghegan
I want to edit the content that is found in the About tab in Flex Viewer to give information about my application. I'm aware there is the option of the splash widget but I would prefer this. Is there a way that I could edit this manually? I though I might be able to edit the configuration file, however this doesn't appear to be a solution.
RobertScheitlin__GISP
Richard,
   It is definitely possible to edit the about screen that is displayed when you click the about link in the HeaderControllerWidget. You can find it in the documentation here: http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Header_Controller_widget_tags/0...
under the links section. You do have to write a little HTML code if you want good formatting.
