Increase the height of the Layer List in the MapSwitcher Widget
4056
02-03-2015 07:21 PM
AndrewNiederhauser1
I'm trying to lengthen the "More..." layer list that is used with the basemap switcher.
I know that adding the height tag like below to the widget reference in the main .config file will increase the height of the layer list widget.
height="200" when opened. However, I want to lengthen the "More..." layer list that comes in next to the basemap switcher. Any help would be appreciated.
Version 3.6
Andrew
AnthonyGiles
Honored Contributor
Andrew,
There are no settings in the config that you can change to make the list longer, you will need to change the source code if you have that ability. The required change is in the MapSwitcherWidget.mxml and you are looking for the BorderContainer  called "opLayersContainer" on line 469:
arcgis-viewer-flex/MapSwitcherWidget.mxml at develop · Esri/arcgis-viewer-flex · GitHub
You can see the current height is set to 180 you would need to increase that.
Regards
Anthony
